When the fan for the CPU is not used because you're watercooling it,
what happens to the chipset heat-pipe that relies on the CPU fan to dissipate the heat? How is this addressed? Are there retail aftermarket clip-on fans for the heat-pipe that would solve this? Any and all suggestions are welcomed.
Thank you in advance.
