tks for your reply =)... i'm really gratefull =)!!!
i installed EVEREST on my pc and some specs are different like the cpu TEMP. in my BIOS it says 48 degrees, but in EVEREST it says 25degrees... which one is right??? EVEREST? i hope so....
soo... here are more specs:
CPU core: 1.3V
Hard Disk temp. : 32 Degrees
GPU temp. : 46 degrees
Cpu temp. : 25 degrees
CPU core 1 temp. : 30 degrees
CPU core 2 temp. : 26 degrees
Motherboard temp. : 30 degrees
Memory Speed:
(DIMM1: Samsung M3 78T6553BG0-CD5) 512MB DDR2-533 (266MHz)
Memory Timmings:
@ 266 MHz 5-4-4-11 (CL-RCD-RP-RAS) / 15-28-2-4-2 (RC-RFC-RRD-WR-WTR)
@ 266 MHz 4-4-4-11 (CL-RCD-RP-RAS) / 15-28-2-4-2 (RC-RFC-RRD-WR-WTR)
@ 200 MHz 3-3-3-8 (CL-RCD-RP-RAS) / 11-21-2-3-2 (RC-RFC-RRD-WR-WTR)
Memory Speed:
)DIMM3: Infineon 64T64000HU3.7A) 512MB DDR2-533 (266MHz)
Memory Timmings:
@ 266 MHz 5-4-4-12 (CL-RCD-RP-RAS) / 16-28-2-4-2 (RC-RFC-RRD-WR-WTR)
@ 266 MHz 4-4-4-12 (CL-RCD-RP-RAS) / 16-28-2-4-2 (RC-RFC-RRD-WR-WTR)
@ 200 MHz 3-3-3-9 (CL-RCD-RP-RAS) / 12-21-2-3-2 (RC-RFC-RRD-WR-WTR)
wich cooler do u think that i should use??? i really don't know wich one to buy...
i live in AFRICA near South Africa, in MOZAMBIQUE!!!
and what can i achieve with my stock cooler???
tks for ur time.. and hope to see you soon here to help me
!!! you and others too =)
PS: tks for the sites =)
