Ok, I'm currently on my new pc, and I'm having an issue:
Basically I've had my pc just freeze, the screen remains unchanged, no bsod, no error popping up, it just freezes. The usb devices, fans all remain lit. I have to restart it and it'll work fine, until it freezes again that is.
I thought it was my hdd, so I bought a new one to test on, and it happened again. I thought it was windows itself, but it happened during a windows install, before it was even loaded.
I then thought it was the sata power cable itself, so I changed it to the 4 pin molex. And while it seems fine now, when I tested it in World of warcraft it did it again.
My vid card seems quite warm (hot is more accurate, tested at 56 degrees idle), but no visual artifacts pop up, no warnings etc.
I don't overclock the system either. Any help would be appreciated.
system specs:
Intel e6600
Asus p5n-e sli motherboard
EVGA 8800gts 320mb
Creative Soundblaster x-fi
Western digital (both hard drives were exactly the same) sata 250 16mb
Asus silent square HSF
Corsair hx520watt psu
I'm trying to figure out what the issue is so I can replace/fix it in time. All drivers (even motherboard bios/drivers) are all up to date as well.
Thx.
edit: also, it shows my SATA drives are removable storage, how do I fix this issue?
system specs:
Intel e6600
EVGA 8800gts 320mb
Thx.
