Help w/ 80mm Fans
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Help w/ 80mm Fans
Well... I need a set of fans for my case that will be able to move some air. I dont think my cooler masters are really cutting it and I want something that will give me a good performance to noise ratio.
Any Advice?
Sponsored Links
Quote :
Any Advice?
An 80mm to 120mm fan adapter would make it possible to improve case air flow and over all cooling quite a bit. A 120mm fan will do much better at moving air than a smaller 80mm. You could use sometning like this x 2.
http://www.newegg.com/Product/Prod [...] 6811999346
Reply to prong
My case only supports 80mm... When I bought my case I didnt even think about it. Great case though still love it.
Reply to pchoi04
Quote :
To improve case cooling, you might try an 80mm to 120mm fan adapter. Find one at your local computer store, like Fry's electronics has them.
http://www.casecooler.com/cl80to12fanf.html
Reply to prong
Cool... thanks! but to bad my case will only allow for one of these but I guess thats better than nothing.
Reply to pchoi04
80mm fans will cool it just fine. Apevia actually makes some good quality cheap case fans. I have an 80mm an 120mm Apevia and they are whisper quiet and move a good amount of air. 80mm have to spin faster to move the same amount of air as a 120mm fan, that is why 120mm fans are more desirable. They are simply quieter at the same cfm rating.
Reply to TSIMonster
Here's probably the best deal you can encounter, a 4 pack of fans for $10, or just buy some of these yate loons, and volt mod them, that's how I'd do it
http://www.xoxide.com/thermaltake- [...] -pack.html
http://www.thermalfx.com/merchant2 [...] ore_Code=T
You can actually find 12cm yate loons for even cheaper, they go for as low as $3
Reply to I_Love_Tacos
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Help w/ 80mm Fans
There are 643 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
