Tom's Hardware > Forum > Home Theatre > HDTV > HELP!! DVI and HDCP issue
Forum Home Theatre : HDTV - HELP!! DVI and HDCP issue
Archived from groups: alt.tv.tech.hdtv (More info?)
:no
I am trying to connect my DVD input from LG DVD/HDTV tuner/up-converter
to my Hyundai 42" plasma using DVI connection, but it complains of the
HDCP compatability issue. I am thinking my plasma TV's DVI input is
not HDCP compliant (since LG tuner spec. says DVI with HDCP).
In this case, is there any way to use software/hardware add-on to my TV
to make it HDCP compliant? Any possibly way to convert it, so TV is
HDCP compliant?
As long as I can watch DVD movies close to HD quality through DVI
interface, I would be happy (I am not still satisfied with component
connection quality).
HD OTA seems working pretty well with minor indoor antenna adjustment,
but if I am not getting DVD working through DVI, I might return my TV
set (I hate to let go, though.)
Any one out there was able to work out this issue?
Thanks in advance!!
BTW, will DirectTV, Dish, or Voom HDTV receiver put out HD signals with
HDCP on their DVI interfaces? If so, there is no point for me to keep
this TV in case I go with satellite HD, is there? Thanks!
ending1
This message was posted via http://www.satelliteguys.us by ending1
Sponsored Links
On Mon, 1 Nov 2004 20:16:09 -0500, ending1
>HDCP compliant?
AFAIK, there is no way to do this.
Component is the only route.
I believe that all new and current DVI outputs are HDCP-compliant. If
you cannot live with composite, you will have to change the TV sooner
or later.
Kal
Reply to Anonymous
Kalman Rubinson <kr4@nyu.edu> wrote in message news:<8iqdo0pp54j69t9qsa2hf5guu2jpgcc2ii@4ax.com>...
> >HDCP compliant?
> or later.
> Kal
And it's unlikely you will notice a difference between DVI and
component anyway, so I wouldn't get upset.
Reply to Anonymous
"ending1" <ending1.1f2krw@satelliteguys.us> wrote in message
news:ending1.1f2krw@satelliteguys.us...
> :no
> to my Hyundai 42" plasma using DVI connection, but it ...
IT... which it... the TV or the LG LST 5310?
I have the LG LST 3510 also, and almost gave up on the DVI connection as
well, until I read the book...
I'm at work and the set is at home, but be sure to do the set-up for the LG
properly... It's tricky be sure to push the button to 'set' the
configuration... that's where I kept missing up, but after the LG is setup,
it works remarkabely well! DVD's in 1080i are ... well only one word will
describe the quality... "WOW", now repeat that about 1000 times...
I have a 27" Samsung LCD and this is set up in the bedroom... can I say that
is the only place I watch tv anymore.
Van Helsing was absolutely unbeleivable, as well as Kill Bill Vol 2.
Haven't done much DVD watching tho, as I've been hung on broadcast OTA HD
quality on CSI, Las Vegas, Law & Order, MNF, and the Sunday ball games just
to name a few. I had Charter HD for one week, and dropped them and bought
the LG. I'm really glad I did as they did not carry CBS HD. I kept basic
cable so I can continue getting my poker fix tho.
>...complains of the
> HDCP compliant?
> Thanks in advance!!
> ending1
Reply to Anonymous
There are 689 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
