Tom's Hardware Forums » Overclocking » General Discussions » Will this build work ok?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Will this build work ok?
Profile: stranger
More Information
First let me say thanks to everyone for all the useful information I've found around here over the last year or so. Finally had to ask a question though, so here's my first post...
I want to build a new system around the E4300 chip on a budget of £1000. I already have an 8800GTX to put in it, and monitors etc. So this is my current shopping list:
MoBo: Gigabyte GA 965P-DS4
CPU: E4300
PSU: Silverstone 750W SSt-ST75ZF
RAM: 2GB Corsair PC2-6400 (800MHz) CL4-4-4-12 (with heat spreader)
Cooler: Noctua NH-U12F
Case: Coolermaster Centurion RC-532
HDD: 4 x Seagate 500GB (16 MB Cache 7200rpm) in raid-5
Fans: 2x120mm Sharkoon 1000 "golf ball"
I have this priced up at £1051 + Delivery but that's ok and by the time I buy it in a few weeks it should have dropped further anyway.
Any recommendations on any changes? The only thing that bothers me about it is that the motherboard doesn't support changing the frequency multipler, so I'm stuck at 9x.
Assuming I don't get a duff cpu this should go ok to 333MHz? Perhaps to 367MHz?
If it does go to 367 then the FSB is working at an effective 1470MHz. Are there any consequences for exceeding the 1066MHz norm that I should be aware of (other than wear on the parts)?
One of the sticky posts recommended 4-4-4-x rated memory for the E6300, does it hold for the E4300? I could save £25 by getting some 5-5-5-x rated OCZ memory instead if the impact would be negligable.
Thanks for any insight you can offer.
Related Pr oduct
Profile: enthusiast
More Information
Quote :
CPU: E4300
Quote :
The CPU determines the multiplier adjustment. As far as I know the multiplier on the 4300 is not unlocked. You can adjust it down from 9x, but not above 9x. You didn't mention your MB specifically.
Quote :
Generally PC6400 5-5-5-15 DIMMS have a lower default voltage than 4-4-4-12 DIMMS. If you are buying high end chips whether OCZ or other, you can generally achieve 4-4-4-12 timings with 5 CAS latency default RAM providing you have high quality chips. You can always bump up the voltage and get stable, tighter timings if need be in most cases. With the 4-4-4-12 DIMMS (at higher voltage defaults) the mfg. is guaranteeing the RAM will run that tight. Some MB (micros generally speaking) need the 1.8 voltage default (5 CAS) to run stable. HTH.
Add a reply
Google Ads
News
Microsoft Releases New Build of Windows Vista
Published on September 25, 2006
Microsoft has released an interim build of Windows Vista to its usual testers as well as to some 100,000 of the participants in its Customer Preview Program. Read more
Microsoft ships first post-beta 2 build of Vista
Published on June 27, 2006
Late Friday, Microsoft shipped Windows Vista build 5456, its first post-Beta 2 version of the next major Windows release. Read more
Microsoft releases Windows Vista RC2 to beta testers
Published on October 06, 2006
Microsoft today released what the company believes will be the last non-final version of the Windows Vista operating system. Vista RC2 promises more stability and more performance than RC1, which was released to a total of five million users earlier this month. Read more
IBM researchers eye 100 TByte tape drive
Published on December 17, 2004
IBM has begun work on new technologies designed to boost the capacity of tape storage devices by 250 times. Read more
Latest Reviews & Articles
Do New Drivers Really Boost Performance?
Published on October 07, 2008
How much extra performance can you get from a simple graphics driver update? And what sort of gaming gains can you expect from a high-end graphics card when you overclock your CPU? Read more
Best Video Cards For The Money: Oct '08
Published on October 06, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
