Tom's Hardware Forums » CPU & Components » CPUs » These temps acceptable for E6600 with Zalman 9700LED cooler?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : These temps acceptable for E6600 with Zalman 9700LED cooler?
Profile: stranger
More Information
P5B motherboard
E6600 OC'd to 3.2GHz at stock voltage
Idling at 40C
Load at 58-59C
thoughts?
Related Pr oduct
Profile: nimble knuckle
More Information
Quote :
P5B motherboard
E6600 OC'd to 3.2GHz at stock cooling
Idling at 40C
Load at 58-59C
thoughts?
That's what I have. I guess it's good enough.
I won't try to push the system any farther.
Profile: old hand
More Information
I am confused, you have a Zalman 9700LED and an Intel stock cooler at the same time?
Profile: stranger
More Information
er no, stock voltage, i fixed it  :idea:
Profile: old hand
More Information
Quote :
P5B motherboard
Idling at 40C
Load at 58-59C
thoughts?
Those temps are fine at that speed. What thermal paste did you use?
Profile: stranger
More Information
The Zalman STG1. I'm tempted to redo it though, not sure whether I put enough on. I turned the fan on high and now its idling at 34/37 for core0/core1
Profile: Forum Veteran
More Information
Those temps are fine.
Profile: Forum Gigolo
More Information
Temps are good, ambient temperature will modulate it quite a bit.  Cool nights you will see lower if the room is cool and the case has good flow through.
Profile: journeyman
More Information
8O  8O  8O  8O Idle at 40C 8O  8O  8O  8O
I idle at 25C w/ Tuniq Tower 120 E6600@3200mHz, 9700 shouldn't be that much higher
Profile: stranger
More Information
what motherboard though?
Add a reply
Google Ads
