Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Crossfire problems/question
Forum Graphic & Displays : Graphics Cards - Crossfire problems/question
Been trying to setup Crossfire with a pair of Sapphire 1950Pros on an ECS KA3 MVP. Both cards work fine independently, but once both cards are installed, and it doesn't matter which card is where, I can not get any video signal out of the second card.
I thought that you had the option to run two cards on a Crossfire motherboard independently, so that you can run four monitors, am I right? And shouldn't I also be getting some type of video output from the second card during boot up will the bios is loading??
So opinions, I have two independently working graphics cards that will not function at the same time when I put them in my motherboard. Where should I starting replacing parts first, the motherboard, or the graphics cards.
Athlon X2 3800+
ECS KA3 MVP
Wintec 2GB DDR2 800
Sapphire 1950Pro x2
Seagate 250GB
Antec TruePower Trio 650
Sponsored Links
There are 1469 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
