So im getting ready to pull the trigger on the 22nd and im looking for some expert advice to finalize my list. The system will be used mostly for general stuff, media and some gaming. My goal is to make a quiet, small computer with some bite to it. I was shooting for an e4300 pushed up to 3 ghz.
Budget is $700
All of the items below ive done some research on, so if you think something else is better please explain why. All advice appreciated, thank you for viewing!!
CASE $80
ULTRA MicroFLy
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=382312
MOBO $110
Foxconn G9657MA-8KS2H LGA 775 Intel G965 Express Micro ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186109
or can somebody tell me the difference between this one ^ and this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186110
I can see that the later has a a chip and a socket near the pci express slot, which are absent from the cheaper borad. Is it stuff i want?
CPU $113
E4300
RAM $119
Corsair TWIN2X2048-5400C4 2GB DDR2-675 XMS2-5400
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=85016-16
or is this better??
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=85016-18
HDD $70
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E16822144701
PSU $67
SeaSonic S12-330 ATX12V 330W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151021
Grand Total : ~$650
Note, ive ommited a video card for the time being since it dosn't seem like a good time to purchase a mid range card, with both NV and ATI's offerings yet to hit the shelves.
Budget is $700
CASE $80
ULTRA MicroFLy
MOBO $110
CPU $113
E4300
RAM $119
or is this better??
HDD $70
PSU $67
Grand Total : ~$650
