Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > New Build - XP - 32bit or 64bit
Hi,
I'm just going to install an OS on a new laptop based around the Core 2 Duo.
Would you install the 32bit or 64bit version of XP?
Any opionions or advantages/disadvantages would be greatfully received :D
Thanx
Sponsored Links
I wouldn't bother with x64 right now. The only place it makes a real difference is if you need more than 4GB of memory, which you won't need on a laptop.
While x64 is stable, there are some incompatibility and driver support issues - some hardware manufacturers aren't even releasing drivers for it since it's not a mainstream OS.
Save yourself some headaches and just get 32-bit XP for now, and wait until Vista for 64-bit.
As far as 32-bit XP goes:
You should use Pro, not Home Edition on your laptop as it has better power management features.
Reply to exit2dos
Nice one :D Kinnda what I was thinking! The less headaches the better ;)
Cheers
Reply to Akira25
There are 1108 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
