buzytee
4
I’m using a notebook HP Pavilion zt1180 with a XP operating system. The problem I’m having is that when the ‘guest login’ is used some software is not accessible, specifically internet access. I can’t get a connection. When I try to check on my wi-fi connections the program doesn’t stay on the screen, it just flashes.
P.S.
Is there a way to control what programs a guest can use from their login.
bacis
330
hi.
to control the programs that a guest must have access you must have administrator rights.
once loged as adm you can specify which programs and folders must access others users.
control panel/user accounts
