Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Serious problem Window XP
I have no idea what is wrong.
Here is my setup when everything was ok:
Disk 1 Internal:
Partition 1: Logical (WINDOWS)
Partition 2: Primary/Actice
Disk 2 Internal:
Disk 3 (USB):
Then I used Partition Magic to change Disk 2 to Primary/Actice. After it is done everything is still fine. Next I did actions below:
Disk 1 Partition 2: Logical
Disk 1 Partition 1: Primary
Disk 1 Partition 1: Set Active
Disk 3 Partition 1: Primary
Disk 3 Partition 1: Set Active
After I pressed Apply, the Partition Magic asked to reboot. But Window does not start, it is just black screen with promp. No matter what I tried it always display black screen. I also tried to reinstall window but it is still same.
Please help.
Thanks
Sponsored Links
hi.
probably there is a conflict between partiotions and your os does not load.
u can try reinstall windows in one disk of these
propably usb disk and after that use partition magic to rejoin the separatet disk.
Reply to bacis
- 0 +
damn man...i'm lost
just dump everything off to a large drive and re-do your partitioning, and don't make so many damn logical partitions, it's confusing! :P
Reply to fattony
- 0 +
Change your active partition back to it's original state. Windows does NOT like it when you change your active boot partition.
Reply to Zoron
There are 1295 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
