I just finished building my 4300 Oced rig, and after all was done, i was not happy with the temperature I was getting a 3GHZ, and the fan noise. I have decided to take the Water plunge for just the CPU, since my powercolor x1950xt has a very quiet fan, and that is very tolerable by itself.
My CPU is the E4300 - OCed to 2700GHZ at the moment, until I get in the water cooler.
my case is the Antec P180 case.
my goals :
-quiet
-reliable
-enough that my CPU can go to 3GHZ-3.15GHZ ---somewhere in that
range.. 3GHZ and QUIET would be definitely sufficient!
-does not have to use an AC adapter to power it.
After reading the water cooling guide, and some people's posts, I am interested in the "Petra'sTech CoolKit Lite". Is that a good choice for my requirements? Would i need anything else? can I use their setup nicely in my rig(replace one of the Antec 120mm fans with their fan and setup nicely in my case and satisfy my requirements?
Price is somewhat flexible, but I do read a lot of good about Petra's tech shop.
thanks!
my goals :
-quiet
-reliable
thanks!
