I bought a 7800GTX 256meg second hand. My 460W PSU doesn't have the PCI-e power plug, so I used the adapter that was in the box. The card seem to run fine so far.
However I notice that only 3 wires goes from the 6-pin header to a male molex, and then 4 wire to a female molex. So only one molex provide the power.
The usual 6-pin adapters I saw so far in pictures on the net have 6 wires from the 6-pin connector, spliting to 2 female molex connector (which I guess provide 2 X molex power to the card).
Do you think I have a wrong PCI-e adapter? Anyone have a 7800gtx and can tell me if their adapter does indeed plug into 2 molex instead of one like for me?
If the card seems to be running fine then you shouldn't have to worry. If its the adapter that came with the card you SHOULD be fine. Usually a power starved graphics card will reward you with heavily degraded performance. What brand is the card and what are the rest of your system specs? Also, run some 3D benchmarks (like 3DMark05/06) so someone can verify your GPU's performance is where it should be.
The adapter on the bundle picture doesn't look like the one I have, so it is why I wonder. Because I bought it opened and second hand, I thought maybe the guy put the wrong cable in the box.
I'll run a benchmark to see what I get.
Thxs for the hint
//***********SYS SPEC***********\\
AMD X2 4800+
EVGA 131-K8-NF44-AX
MSI 7800GTX PCI-e 256meg
1.5gig RAM OCZ Premier
Enermax EG465P-VE
74 gig Raptor
320 gig Seagate SATA II
