I just orderd a 4GB flash drive. (patriot) off newegg.
My question is most of these other drives come preloaded with a software called u3? or something like that. I was just wondering if it's something you can just get.
and also if i wanted to run mozilla firefox off it will this require an OS system on there?
and if i install an OS.. how much faster will booting and what not be with a flash drive instead of using your hard drive.
if i just use the flash drive as my primary main drive. will this blow away a 7200rpm drive?
and finally how long does it take to load an OS on one of these drives.
Thank You.
Rob.
__________
Sponsored Links
hi
to get these answers there is only a way.
u can try it and tell the rest on how fast is it the os booting.
however your mobo must support booting fron usb.
Reply to bacis
Quote :
Let's see: For specs we have:
USB 2.0 = 480Mbps
ATA100 = 800Mbps
ATA133 = 1064Mbps
SATA = 1200Mbps
SATAII = 2400Mbps
OK, so you're starting with a significant disadvantage just in the interface. However, hard drives do not maintain the spec max as a "sustained" data transfer rate. Neither do flash drives. The flash drive you bought is spec'ed at 32MB/s read speed. This compares with an Hitachi Deskstar 7200 PATA 133 drive's speced sustained transfer rate of 64.8 - 31MB/s, depending on where the data is physically on the drive.
So, bottom line, it won't be faster.
Reply to Iceblue
excellent thank you for that.
Ok so in what way can i use this FLash as an advantage in my PC
Since i have a 4GB stick, and i have 1GB physical memory... can this be said that i can have 5GB for Vista? or that is not a valid statement.
Cause i did read you can use removeable drives as shared memory for the system.
Reply to Rob423
Using it for memory, if it were even possible would slow your system down even more since memory transfer speeds are faster than hard drive speeds.
On a side note, you can definitly transfer more porn to your work computer! :o
Reply to sturm
you can throw your page file on the usb drive, paging will be fast as hell
Reply to fattony
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Using a FLASH device..
There are 1201 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
