C2D mobos are now required to boot RAM at 1.8v, regardless of what speed, voltage, or timings. That is a current industry standard to ensure compatibility.
However, that does not meant that your 800 RAM will then perform at rated speeds. This is because IF your RAM, for example, is rated 800 @ 4-4-4-12 @ 2.0v, then you will need to boost vDIMM +0.2v to get it
back up to its rated specifications. It's not whether or not it's overclocked....it's whether it's running at its rated specs or not.
So, trying to run at 4-4-4-12, for example, at 1.8v may crash if it's rated at 1.9 or 2.0v.
There's your answer, hope that clears it up
As for northbridge block......depends on:
-how high you wanna OC
-if your loop take take the added block and flow drop
-if you don't want to use a simple air heatsink for cheap that'll do the trick
-if you want bragging rights
Answer those and you'll have your course of direction.
SpeedFan AFAIK for northbridge temps......I think.
