Need quick fix HELP!
Last response: in Opinions and Experiences
OK - I just found your other post in the Vista sub-Forum.
If you have the same "Direct Server Frame. create TBO _ IE Access is denied" problem as the OP in that thread, try going into Internet Explorer>Tools menu>Internet Options and under the Advanced tab, tick "Disable script debugging (IE)" and "Disable script debugging (Other)" then untick "Display a notification of every script error"> Click Apply and OK your way out then restart IE and see if that helped.
Ask the community
