well i got this motherboard and may of ran into a problem
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138034
well i ordered a 8800gts and it should be here tomorrow and i relized the south bridge heatsink seems to be rite under the pcie slot. so im worrying that the 8800 will hit that and not go into the pcie slot all the way. so i figured if it dont fit i can remove heat sink and cut some of the fins a few mm until it fits.so would that work and how do i get the heatsink off??
