I'm building this PC to put away my laptop which I have been using for games for the past year. Budget is no more than 2k, pretty firm on that.
So far this is what Im looking at, please offer advice/input on what should change etc.
Case is: Antec P182 159.99
I tossed and turned on which case to get for the better part of 2 weeks. Currently I have the P182 sitting in my room but may return it to Frys. My other choices are a P180/P180 black or Antec 900. My issues with these 3 other cases is the lack of cable management. Another major issue I have with the 900 is the side window having the open mesh, I have cats need I say more. But I could probably work around that, but cable management is pretty huge for me...I don't want this system to be a mess and I want it to have great airflow and look nice. Without the cable management how well can I clean the cables up?
CPU:E6600 $308 (Soon to be cheaper)
Hard Drive: Seagate Barracuda 7200.10 ST3320620AS 320gb $80
DVD Drive: Something Sata
Graphics: Trying to swing a 8800GTX but may get the 8800 320mb then use EVGA90days to upgrade to the 8800GTX $279-559...actually I know I will in hopes of the GTX dropping a little in price.
Cooler: Tuniq Tower $50-65
Monitor: Samsung 22inc 225BW $299
PSU: OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply $149.99
Motherboard: This is an issue P5B Deluxe/WiFi P65 192.99 or Gigabyte DS3 $122.99
Im looking to overclock the E6600 to 3.4Ghz range, this will be my very first OC so I need something that isn't going to be a major pita and is hopefully fairly easy to use.
Memory: 2gb-3gb No clue whatsoever. To be quite honest I wont OC right off the bat, so Im looking for something that I can drop into the mobo and have the system boot up without any problems or needing to update the settings etc.
OS: XP Pro $100 (No Vista for now)
With this PC Im looking to play the normal games, Oblivion, HL2, Stalker, few older games, and of course anything new that comes out.
Looking for as much help as I can get. I have a tax refund burning a major hole in my pocket!
