Hello Fine people
This is my first post here.
The reason why I post this is that im going 2 get a completely new system.
Short info: The Conroe is going 2 be clocked on a later time, and then i will buy a better cooler. And the reason for the same harddrives are because i want them 2 run in RAID.
The questions is:
1. Do you have any advice about changing hardware. fx. how can i get more performance, and so on?
2. Do the parts fit together?
3. Whats the - and + about the system?
I hope u will help me - Thx in advance
Hardware list:
Ram: http://www.edbpriser.dk/Products/Listprices.asp?ID=253411
Corsair XMS2 Dominator Xtreme Performance TwinX Matched
2 x 1 GB (2 GB) / DUAL RAM / DDR II SDRAM / PC2-6400CL4 / 800 MHz / ? Bit? ns
Ramcooling: http://www.edbpriser.dk/Products/Listprices.asp?ID=252893
Corsair DOMINATOR Airflow
GFX card: http://www.edbpriser.dk/Products/Listprices.asp?ID=346850
BFG GeForce 8800 GTX OC2
Motherboard: http://www.edbpriser.dk/Products/Listprices.asp?ID=255956
EVGA nForce 680i SLI
LGA775 Socket / NVIDIA nForce 680i SLI / 1333 MHz / ATX
Processor: http://www.edbpriser.dk/Products/Listprices.asp?ID=216462
Intel Core 2 Duo E6600 2.4 GHz / 1066 MHz
SoundCard: http://www.edbpriser.dk/Products/Listprices.asp?ID=153540
Creative Sound Blaster X-Fi Fatal1ty FPS
Powersupply: http://www.edbpriser.dk/Products/Listprices.asp?ID=205049
OCZ GameXStream 700w
Case: http://www.edbpriser.dk/Products/Listprices.asp?ID=308471
Antec P180 Advanced Super Mid Tower
harddisk 1: http://www.edbpriser.dk/Products/Listprices.asp?ID=177268
WD Raptor WD1500ADFD
150 GB / 10000 rpm / 16 MB / Serial ATA-150 / 4.6 ms
harddisk 2: http://www.edbpriser.dk/Products/Listprices.asp?ID=177268
cd-dvd drev: http://www.edbpriser.dk/Products/Listprices.asp?ID=246978
Samsung Write Master SH-S183A S-ATA DVD RW
The questions is:
Hardware list:
