Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Process Guard loading problems (running as a limited user)
Forum Windows XP : Windows XP General Discussion - Process Guard loading problems (running as a limited user)
I run a non-admin account for daily use, and have had to find some workarounds to get certain programs running. For example, to get core temp running, I had to make a script that loads at startup to load the program as admin (I have to manually enter that password on startup).
For some reason, Process Guard loads fine when I log in as admin, but when I log in on my other account, it fails to initialize. The procguard.exe window tells me to check DCSUserProt.exe. But the task manager shows that it is running..
When I load admin account first, then switch to my other account, it won't load PG and says it is already in use on another account. How do I get around this problem as well?
Also any links to information on running a non-admin account in general would be helpful, as I've had a few other weird problems. Is it even worth it to not run under an admin account in XP?
I'm using XP SP2 behind ZA suite, nod32 and a netgear WNR834b router.
Sponsored Links
There are 1259 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
