I recently upgraded to XP. However, for some reason the start bar is gone. When I hit the windows button nothing happens. I was messing around with desktop themes and switched to windows classic I saw the top edge of the toolbar and did something to bring it back then switched to back to the XP theme if I leave it unlocked I can see the top of the bar on restarted and click on toolbars desktop and it will pop back out.
Whenever I minimize a screen like this internet explorer window it gets small and goes to the corner of the screen but still no tool bar. How do I get it back?
I've also noticed considereably slower system preformence could this be a bad install?
Tried it but it didn't work toolbar still doesn't act right and I still have a longer wait when starting windows. Also I noticed that my internet doesn't connect as it use to. It takes a further 4-6 min at start up before it will connect.
If I run 2 or more programs I get a low virtual memory problem
I'll try to get ahold of a disk in the mean time I'm going to try that repair option when installing.
Also is their some type of sys req with XP? This computer is from 2000 and came with ME. When I first installed windows I just did the upgrade option and ME and XP were both on their and I noticed there were problems so I was able to delete the parationed space and installed XP and I did chose the NTFS option when I did it.
Make sure you wipe out all the partitions with fdisk.
I've seen it run on 128mb of ram. XP just uses the pagefile to a GREAT extent in that low memory situation.
DO NOT BOTHER REPAIRING WHAT YOU HAVE!
You need to do a clean install.
It sounds like you may have the "Upgrade" version of XP. You will need a Windows 95, 98, or ME installation cd (borrow one if you have to) to put in during the beginning of the install to verify ownership of a previous windows. You just pop it in to the cd drive when prompted, and you will be told when to take it out.
Ya it is an upgrade version. Ok I understand now my old ME was probally screwed up to begin with so when I added XP it was screwed to. But before I deleted ME and XP completly and I just used the XP cd
so now I should install ME first and then XP once ME is fully installed? It never asked for the ME disk the second time I installed it. The XP came with its own CD key
Just have the ME cd handy when the XP installation asks for verification of a previous Windows. You pop it in; the install looks at it; the install continues and asks for the XP cd to be put back in after you remove the ME.
Once I get that then all I have to do is restart with the disk in and type fdisk and delete tha partioned space pop the disk out and then put in the XP cd and install?
After you download it, you put a "clean" floppy in the "A" drive, locate the download and double-click it. It will put all the files for the boot floppy on the diskette.
You said you have an "Upgrade" XP cd. Do you or don't you?
If you do, that message was probably along the lines of not finding a qualifying Windows installation and that you had to insert your ME at that point.
If you want to live with the WORST OPERATING SYSTEM ever assembled, be my guest!
And, if you're embarassed because I'm right, and then try to install XP over ME - then you're an idiot!
Listen to me Bob. This is my last post on this thread! I will walk you through this again. I've done this exact install about 500 times!!!!!!!!!!!
The Upgrade cd you have WILL install XP - it WILL install - it WILL indeed install.
Kill the partition with fdisk again. This will wipe out the Fat32 ME that you installed, that you don't have to install, and which you really don't want.
Make sure the cd drive is FIRST in the boot order up inside your BIOS. You have to hit a key to get in there - usually Del, or F1, or F2 - there should be a message about that as you first start up the comp. Nose around in there & look for something like boot order or boot priority. Set cd drive first, floppy second, hard drive third.
Pop in the XP cd to start everything going. For about 3-4 minutes Setup will load a bunch of files. Then it comes to a stop with a screen with three options: Install, Repair, Quit.
You will press Enter to continue the install. Immediately you will be asked to press F8 to say okay to the "Licensing Agreement" Press F8.
You will then come to a stop again, and this screen will say:
"Setup cannot find a previous version of Windows installed on your computer. To continue, Setup needs to verify that you qualify to use this upgrade product.
Please insert.................." and it lists all the qualifying flavors of Windows that it will accept - one of which is your ME cd.
Open the cd tray - take out the XP Upgrade and put in the ME cd. Setup will look at it, and in about 5-7 seconds will continue the install. Setup will ask you to put back the XP Upgrade cd after a few more seconds has elapsed. You open the tray - take out your ME cd and put back the XP.
Setup will continue and you will have a clean fresh XP in about 35 minutes. Make sure at the partitioning & formatting screen you choose all the space it will let you use, and you choose the NTFS format - but not the Quick.
PRINT THIS OUT SO YOU CAN FOLLOW IT STEP BY STEP - checking off as you make progress.
