Ok... here we go. I'm putting together a new system and would like some power supply advice. Here are the components I have selected:
Core 2 duo - E6420
Asus P5B-E
2 GB (2X1GB) DDR2
A 7600GT based Video card
3 Sata II HDs (2 raided and one for OS)
1 Sata DVD/RW
I'm thinking about getting this Thermaltake power supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153028
Will this PS work for me? The total amps on the combined 12V rails is fine but I'm concerned I'll run into problems on 12V1 (HDs, vidoecard... etc).
If not, are there any other good PS in that price range (~$50) that will work?
Core 2 duo - E6420
Asus P5B-E
2 GB (2X1GB) DDR2
1 Sata DVD/RW
