Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Radeon X1650 Pro AGP problems
Forum Windows XP : Windows XP General Discussion - Radeon X1650 Pro AGP problems
Hello i bought a X1650 Pro agp i installed it just fine once i put it in and put in the latest drivers and was running oblivion just fine. I forgot to uninstall my old drivers so i proceded to do that and then my ati drivers and then tried to reinstall them and it starts to then it says it wont be able to due to some error saying that i need to reinstall my old agp drivers before it will be able to install the ati drivers. Any help please
Sponsored Links
Run Driver Cleaner. It should completely remove all ATI drivers - then re-install the new ones.
Reply to exit2dos
Make sure you have upgraded to the latest DirectX first (9.0c).
http://www.softwarepatch.com/windows/directx.html
Reply to pscowboy
Thanks for the tip i will check that out once i get home. I have directx9.0c already.
Reply to jblatz
There are 1149 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
