Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Removing directory containing unused "System Volume Inform..
Forum Windows XP : Windows XP General Discussion - Removing directory containing unused "System Volume Inform..
Archived from groups: microsoft.public.windowsxp.basics (More info?)
One of my hdd's had been partitioned into 3, using partition magic. I
merged one small, empty partition into one of the remaining 2. PM
placed the files on this small, now defunct partition (Recycler & System
Volume Information) into a folder in the partition to which the smaller
partition was merged. When I try to delete this folder, I get the
infuriating "access denied" (ever have your car tell you "access denied"
when you attempt to make a left turn or open the glove box? ;-). How
can I get rid of this file? I tried resetting its attributes to remove
"read only", but it keeps resetting them immediately. Also tried
deleting it from a safe mode command prompt (ever miss dos???), no dice.
It takes up no space, but just as a matter of principle I want to get
rid of it ;-)
TIA
Dan
Sponsored Links
Hi Dan,
Recycler is the Recycle Bin from the deleted partition.
System Volume Information is where System Restore stored it's files
for that partition.
You will have to take ownership of the folders to delete them.
How to take ownership of a file or folder in Windows XP:
http://support.microsoft.com/defau [...] -us;308421
Regards,
Bert Kinney MS-MVP Shell/User
http://dts-l.org/
> partition magic. I merged one small, empty partition
> into one of the remaining 2. PM placed the files on this
> small, now defunct partition (Recycler & System Volume
> smaller partition was merged. When I try to delete this
> folder, I get the infuriating "access denied" (ever have
> your car tell you "access denied" when you attempt to
> make a left turn or open the glove box? ;-). How can I
> to remove "read only", but it keeps resetting them
> immediately. Also tried deleting it from a safe mode
> command prompt (ever miss dos???), no dice. It takes up
> rid of it ;-)
> TIA
> Dan
Reply to Anonymous
Bert-Thanks for the reply. Yeah, I knew what the files were, I was just
surprised that since they weren't the files for the current OS (actually
on another hdd altogether) that I could not access them. The process
you pointed out did the trick, but what a rigamaroll!!! I noticed when I
checked the "ownership" (What a concept! Silly me, I thought I had
"ownership" when I BOUGHT the damned machine! ;-) that it had it set as
"administrator", rather than the "name" I picked when installing the OS
(which I did just recently). I could have sworn I set my "name" as
having "administrator" privileges! How can I once and for all get ALL
access to ALL aspects of the PC under my default log in? I am the only
one using this box, frankly I've always found all this "name/login
id/administrator" stuff to be a real pita on a single user PC.
Thanks again!
Dan
Bert Kinney wrote:
> Hi Dan,
> for that partition.
Reply to Dan
"Dan" <"prograde49 NO SPAMMIN "@hotmail.com> wrote in message
news:uiISSkPSFHA.3496@TK2MSFTNGP12.phx.gbl
> Thanks again!
> Dan
If the OS is WinXP, certain folders and files 'belong' to the operating
system, not to you. Not even to the Administrator.
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup only. Do not send email
http://www.fjsmjs.com
Protect your PC
http://www.microsoft.com./athome/s [...] fault.aspx
http://defendingyourmachine.blogspot.com/
Reply to Anonymous
You're welcome Dan and thanks for the feed back.
Frank Saunders has answered you question concerning ownership.
Regards,
http://dts-l.org/
> were, I was just surprised that since they weren't the
> files for the current OS (actually on another hdd
> noticed when I checked the "ownership" (What a concept!
> Silly me, I thought I had "ownership" when I BOUGHT the
> installing the OS (which I did just recently). I could
> have sworn I set my "name" as having "administrator"
> privileges! How can I once and for all get ALL access to
> only one using this box, frankly I've always found all
> this "name/login id/administrator" stuff to be a real
> Thanks again!
> Dan
> Bert Kinney wrote:
>> Hi Dan,
>> it's files for that partition.
>> them. How to take ownership of a file or folder in Windows XP:
Reply to Anonymous
Thanks Frank, I guess what confused me was that on this particular file,
the owner was said to be administrator. Under safe mode as Bert
explained I signed in as my log in (not administrator, since I thought I
had all those privileges, the log in name is listed as having such in
control panel/user accounts) yet still I had to add my log in to the
owner list, although it had administrator listed there already. If my
log in is named as administrator in cp/user accounts, does this mean I
have as much access as I am going to without taking "unusual" measures,
like the safe mode dodge? Is there a particularly good site for info on
all these access/privileges issues?
Dan
>> Thanks again!
>> Dan
Reply to Dan
There are 1068 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
