Hello All,
Recently I changed my mother board to a slightly better one. What I have now is the NVIDIA Nforce 2 Chipset Based MSI K7N2 Delta - ILSR. The board is AMD socket A based. The processor I have is an AMD XP 3000+.
The problem I have is when I boot up the processor is seen as being a 1300MHZ. So it’s running at less than half speed!
I don’t really know anything about overclocking processors, so this is what my bios displays under the Advanced Chipset Features :
ADVANCED CHIPSET FEATURES
Current CPU Clock 1300MHZ
System Performance High Performance
CPU FSB CLOCK 166MHZ
X Cpu Interface High Performance
X FSB/Dram Ratio Auto
Current Dram Clock Auto
X Memory Timings High Performance
X T - RAS 7
X T - RCD 3
X T - RP 3
X CAS Latency 2.5
X FSB Spread Spectrum Disabled
X AGP Spread Spectrum Disabled
AGP 8X Support Enabled
AGP Fast Write Support Enabled
System Bios Cacheable Disabled
Video Ram Cacheable Disabled
AGP Aperture Size (mb) 64M
What I’ve tried so far is :
1. Re-flash the bios
2. made sure the mother board jumper is not set to the safe 100mhz mode
3. wipped and reset the bios
4. Loading up the High performance and low performance bios settings. :roll:
But of course that has been in vein. I’m sure it’s probably something to do with the bios needing to be tweaked, but I’m not sure where to start, so I’m asking the experts!
Some other details that may be of use is that I’m using 2.5 gigs of Crucial unbuffered DDR pc3200 RAM and a Trust 550Wat PSU, last of all my bios version is W6570NMS V7.8 090204 (which is the latest version).
Any help would be muchly appreciated,
Cheers
Greg (aka Ovoco5)
X T - RAS 7
X T - RCD 3
X T - RP 3
X CAS Latency 2.5
Cheers
Greg (aka Ovoco5)
