I have no problems when I first turn on my computer, but after the computer has been running for a while, or after running 3D Mark 06, games start freezing during play (GTA San Andreas and NFS Carbon.) It will quickly freeze and then play, freeze then play. This also happens when trying to scroll across the map on GTA, the movement isn’t smooth, it keeps briefly stopping and going. After restart, the problem temporarily goes away. I am running the latest nvidia drivers.
Also all the tempters are OK
Hardware:
GeForce 8800GTX
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 Timing 4-4-4-12 2.1V
ASUS M2N32-SLI Deluxe Wireless Edition Socket AM2 NVIDIA nForce 590 SLI
Antec TRUEPOWERII TPII-550
AMD Athlon 64 X2 4600+ Windsor 2.4GHz 2 x 512KB L2
Western Digital Caviar SE16 WD3200KS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s
Windows XP 32bit SP2
