Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > Spb Pocket Plus problem
Forum Smartphones & PDAs : Windows Mobile - Spb Pocket Plus problem
Archived from groups: microsoft.public.pocketpc (More info?)
I used Pocket Plus 1.x on my Toshiba e755 and loved it. Just got an
iPaq rx3115 and installed Pocket Plus 2.5 on it. Lots of new features.
That's great. But I've got two problems and don't know if they're due
to the iPaq or the new Pocket Plus version.
#1 -- When I click the Pocket Plus icon on my Today menu it opens the
Pocket Plus Settings screen. There's the features you can add by
checking the box, and below is the "Features Options" box. When I click
on the Features Options box, nothing happens. The box shows that I'm
pressing it, but it doesn't open any more variables. How come?
#2 -- In the older version I used the Backlight icon on my Today screen
to adjust screen brightness. Very handy. But the Backlight icon in 2.5
on my iPaq doesn't have a "slider" control, so there's no way to make
the control DO anything. If you press it, it just takes you to the
internal controls in Settings/System. That can't be the way it's
supposed to work.
Anybody else having these problems?
WC
Sponsored Links
I don't know about #1, I can't reproduce the problem on my PDA2k. Regarding
#2, usually this happens in devices for which backlight level is not
supported by Spb.
Helio Diamant
MS-MVP/Mobile Devices
www.pocketpcfreak.com
"WCH" <DELwhexeterETE@yahoo.com> wrote in message
news:euWdnXQl5fxaIUffRVn-jw@comcast.com...
>I used Pocket Plus 1.x on my Toshiba e755 and loved it. Just got an iPaq
>rx3115 and installed Pocket Plus 2.5 on it. Lots of new features. That's
>great. But I've got two problems and don't know if they're due to the iPaq
> Pocket Plus Settings screen. There's the features you can add by checking
> the box, and below is the "Features Options" box. When I click on the
> Features Options box, nothing happens. The box shows that I'm pressing
> #2 -- In the older version I used the Backlight icon on my Today screen to
> adjust screen brightness. Very handy. But the Backlight icon in 2.5 on
> my iPaq doesn't have a "slider" control, so there's no way to make the
> control DO anything. If you press it, it just takes you to the internal
> controls in Settings/System. That can't be the way it's supposed to work.
> WC
Reply to Anonymous
RE #1 you have your item selected (Highlighted) before tapping it's
settings?
Regarding
> supported by Spb.
> Helio Diamant
iPaq
That's
iPaq
checking
the
pressing
screen to
on
the
internal
work.
> > WC
Posted with QMail3 on
Dell Axim X30
http://q3.snak.org/wiki/
Reply to Anonymous
> settings?
You are exactly correct! I did not understand the relationship between
the items and the Further Options button. One down, one to go.
> Regarding
>>supported by Spb.
>>Helio Diamant
> iPaq
> That's
> iPaq
> checking
> the
> pressing
> screen to
> on
> the
> internal
> work.
>>>WC
> Dell Axim X30
Reply to Anonymous
Good! Glad to hear it.
@#2 - It does say that the compatability is an issue according to the
Spb Website. I notice that if I do a soft reset, my device will work.
However, it fails to work after a time so it is a problem.
At 18 Jul 2005 11:58:09 -0400 WCH wrote:
> > settings?
> > Regarding
supported by Spb.
> >>Helio Diamant
> > iPaq
> > That's
the
> > iPaq
the Pocket Plus Settings screen. There's the features you can add by
> > checking
> > the
> > pressing
> > screen to
> > on
> > the
> > internal
> > work.
> >>>WC
> > Dell Axim X30
Dell Axim X30
Reply to Anonymous
There are 921 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
