Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > A little problem with Ventrilo
Forum Windows XP : Windows XP General Discussion - A little problem with Ventrilo
So my problem is that I can't put in new server information for my ventrilo client. Here is what I see:
http://i1.tinypic.com/4btnfa8.jpg
So I uninstalled and deleted it from my registry but it still does the same thing. What should I do to fix this problem?
Sponsored Links
possibly a bad installer? That's new to me...
Uninstall and try a different version...
or if anyone else has any other suggestions, I've never encountered any problems with Vent before
Reply to CHEEZball
Are you using this method ?
click me !
Reply to hubbardt
Well I fixed it somehow. I installed two previous versions and then installed the latest and it works. So I'm good but thanks.
Reply to Palinko
There are 505 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
