Hi all,
just wondered whether you could help me on a problem i've been having since quite some time. The problem is that half of the times i shut down my computer, it hangs. I just get a blue screen with the windows xp logo, where you should normally see "windows is saving your settings", and "windows is shutting down".
I'm quite sure this is caused by some software, since i have the same problem on all the PC's at home. (I've installed about the same programs on all of them). If it is a software issue, it is likely to be caused by either zonealarm or McAffee Virusscan 8.0i.
However, i don't really know what to do about it... Any help?
My system is as follows:
Windows Xp home, SP2
intel core 2 duo E6600
2 GB Corsair DDR2-800
Seagate 320GB, 7200.16
Sapphire X1900XT 256
