pesonally I say pro with 32bit, I have had home before and will never go back to it again, tho they suppose to be the same for my purposes, running multiple software and etc, home did not do.
so I recommend pro others will say home, you decide at the end
But I'd say go with Home versus Pro because it's cheaper than pro and you'll never use the advanced features that Pro has. Unless you're setting up a dual-CPU workstation (I said dual-cpu, not dual-core cpu), or using the IIS features, you don't need Pro.
lol I have had this discussion already, some apps won't work with home. but as I said that is just my opinion, but if you are just gonna use it for games and regular stuff home is fine, personally I like to only advise what I would do myself and I would get the pro.
