Good Day,
I have pieced together the following system. ;
Emachine's T6524 AMD Athlon 64 3500+ 2.19 GHz / 2GB DDR /A WDC 200GB HDD/ Dual Layer DVD±RW/ Integrated ATI Radeon Xpress 200 / Flash Media Reader / Windows XP Media Center 2005/
I have added the following upgrades
250GB Hitachi HDD a total of 450GB
An extra gig of DDR Ram Total 2.GB of DDR Ram
Nividia Ge-force 7600 GS 512MB
I replaced the stock CPU cooler with an NT04 by Silverstone
I replaced the exhaust Fan with an 120mm LED 3 speed TRICOOL
Creative Sound Blaster Audigy 2 (Sound Card)
I've replaced the 300watt PS with a 400watt PS (I still feel light in power)
VIPER 2 Case by XG (see case @XGBOX.COM) I have the Black color case
How much more can I get out of the AMD Athlon 64 3500+ .
any suggestions would be greatly appreciated I have passed all the Microsoft scans for the vista program questions is should I wait and build a beefer system in the future.
MOBO INFORMATION
Motherboard ID 07/21/2005-RS480-SB400-6A666M4DC-00
Motherboard Name MSI RS482M2/RX482M2 (MS-7093)
Bus Type AMD Hammer
Real Clock 200 MHz
Effective Clock 200 MHz
HyperTransport Clock 1000 MHz
Memory Bus Properties
Bus Type Dual DDR SDRAM
Bus Width 128-bit
Real Clock 199 MHz (DDR)
Effective Clock 398 MHz
Bandwidth 6366 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1 Socket 939
Expansion Slots 3 PCI, 1 PCI-E x16
RAM Slots 4 DDR DIMM
Integrated Devices Audio, Video, LAN, IEEE-1394
Form Factor Micro ATX
Motherboard Size 240 mm x 240 mm
Motherboard Chipset RS482/RX482
Motherboard Manufacturer
Company Name Micro-Star International
BIOS Information
BIOS Type Award
Award BIOS Type Phoenix - Award BIOS v6.00PG
Award BIOS Message W7184AE7 V0.08 072105 17:48:49
System BIOS Date 07/21/05
Video BIOS Date 04/12/06
Company Name Phoenix Technologies Ltd.
______________________________________________________________________________
cpu information
CPU Type AMD Athlon 64, 2200 MHz (11 x 200) 3500
CPU Alias Venice S939
CPU Stepping DH-E6
Instruction Set x86, x86-64, MMX, 3DNow!, SSE, SSE2, SSE3
Min / Max CPU Multiplier 4x / 11x
L1 Code Cache 64 KB (Parity)
L1 Data Cache 64 KB (ECC)
L2 Cache 512 KB (On-Die, ECC, Full-Speed)
CPU Physical Info
Package Type 939 Pin uOPGA
Package Size 4.00 cm x 4.00 cm
Transistors 68.5 million
Process Technology 11Mi, 90 nm, CMOS, Cu, SOI
Die Size 84 mm2
Core Voltage 1.100 - 1.450 V
I/O Voltage 1.2 V + 2.5 V
Maximum Power 67.0 W
I have ran the Microsoft scan and pass on all areas for the new VISTA program. Looking at what I have should I wait to get a beefer system.
Thanks
MOBO INFORMATION
Bus Type AMD Hammer
Real Clock 200 MHz
Bus Width 128-bit
Bandwidth 6366 MB/s
BIOS Information
BIOS Type Award
cpu information
CPU Stepping DH-E6
CPU Physical Info
Die Size 84 mm2
Thanks
