Heres my setup:
biostar geforce 6100-m9 939
artic cooling freezer 64 pro 92mm cooler
amd athlon 4000+ san deigo 2.4g socket 939
(1) 120mm fan blowing out rear
(1) 80mm fan blowing out the top
(2) 80mm fan blowing out the front
(1) 80mm fan blowing in on the side
when i first installed everything my cpu idled a 36 degrees c. speedfan tells me the cpu fan is spinning at 18000rpms which is not possible. since the install 3 weeks ago, i sit around 42 degrees c and about 50 degrees on full load. speed fan reconizes my mo-bo. i need to get a fan controller to control the other fans cause they are all molex connector and speedfan does control them. a buddy of mine has the same set up roughly and his idles at 30 degrees c and 40 at full load. any ideas to get the temps down. i also noticed a little grease oozing out the side of the processor from when i pushed down on the heat sink. is that to much to use? help is much appreciated. thank you.
