Ok so heres my specs to start:
intel C2D E6400
Gigabyte DS3
2gb OCZ pc-6400
BFG 8800gts 320mb
250gb WD caviar
Corsair HX520w PSU
Vista premium x64
and the problemo:
So after getting really excited recieving my £900 worth of stuff i set out to build my first ever PC. Everything went great and had no troubles apart from finding cabling hard. Install vista on the dektop that is way off resolution that i had expexted and then went to install the driver CD that came with my GFX Card containing the drivers. IM feeling so excited
To my dissapointment when the drivers get to the end of the installation i get the message: "No changes were made to your computer, please reinsert the CD to try again at a later time"
BUMMER! the dam drivers wouldnt install. so i thought id give it another go, same problem. i restart, no different. the card doesnt show up in the device manager and im unsure if it should before drivers?
would the vista install detect it on installation and just have it woth no drivers or is it normal to just have the Standard VGA graphics adapter" that i currently hve in the device manager.
so anyone know what the problem is?
PS.
The 24 pin and ATX 12v are plugged in
The single PCI-E power cable to power the card is in
and i THINK it is seated correctly, its in as far as it can go and is clicked into the slot and screwed in
intel C2D E6400
Gigabyte DS3
2gb OCZ pc-6400
BFG 8800gts 320mb
250gb WD caviar
Corsair HX520w PSU
Vista premium x64
and the problemo:
PS.
