I am following Sanji's Guide to Gaming PCs on a Budget ($500 build)here: http://forumz.tomshardware.com/hardware/Sanji-Guide-Gaming-PCs-Budget-ftopict228067.html
Absolutely AMAZING job he did, BTW!!!
Here are the parts I plan on ordering:
Motherboard: BIOSTAR TFORCE 550 Socket AM2 NVIDIA nForce 550 MCP ATX AMD $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138026
CPU: AMD Athlon 64 X2 3600+ Brisbane 1.9GHz 2 x 512KB L2 Cache Socket AM2 $65.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103036
Memory: Kingston 1GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) $53.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134045
Switch to the DDR2 800 instead of 667
GPU: EVGA 256-P2-N615-TX GeForce 7600GT 256MB 128-bit GDDR3 PCI Express x16 $109.99
http://www.newegg.com/Product/Product.asp?Item=N82E16814130062
CPU Cooler: Thermaltake CL-P0114 120mm CPU Cooler $44.99
http://www.newegg.com/Product/Product.asp?Item=N82E16835106061
Thermal Paste: Arctic Silver 5 Thermal Compound $5.99
http://www.newegg.com/Product/Product.asp?item=N82E16835100007
Grand Total with 2gb RAM: $413.94 +S/H
This is my old Power Supply: Thermaltake 430W http://www.newegg.com/Product/Product.asp?Item=N82E16817153023
This is the one he suggested: Hiper Type-R 480w
http://www.newegg.com/Product/Product.asp?Item=N82E16817128005
Any reason I cannot just use my old power supply? I will not have any peripherals hooked up (ie scanners, printers, cameras, etc.) This computer is just for gaming.
One other thing: Any reason not to use the DDR2 800 RAM? This ram has same latency and timing as the set Sanji suggested for nearly the same price: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
Does it interfere with overclocking potential?
I should probably buy a couple of case fans as well. My case has 2 inch x 2 inch mounting holes. Any suggestions?
Thanks a lot for any advice, you guys and this community are amazing!
Cheers!
Hamarabi
Cheers!
Hamarabi
