I just installed Vista on my home built 64 bit PC and I'm already regretting it. As I type this I am in Vista and it's working. HOWEVER, i have a lot of problems:
1. I had to dig deep in google to find 64 bit drivers for my Linksys 802.11g wireless adapter (PCI). When I finally found them (NOT on Linksys's site) they were the XP 64 bit drivers. Thankfully they work in Vista though. Still, they aren't the proper drivers and linksys didn't have them on their site.
2. RAID: i have a dual raptor raid setup. I absolutely could not get Vista to install on the RAID array. Trust me, I tried everything. The problem is lack of 64 bit support for the NVRAID drivers... the drivers exist but don't work right. Anyways, I ended up having to install Vista on a 320GB single drive.
3. SATA JBOD RAID. My system has a silicon image RAID controller which I use in JBOD mode. Silicon Image doesn't not have a 64bit version of its drivers for Vista. So now I cannot access ANY of my data from Vista. Now I'm going to have to dual boot WinXP to get the data off.
4. Sound drivers: intially they didn't work. But Windows Update and installed them quickly. So problem solved.
My advice: if you have a system with any type of RAID setup OR a Linksys wireless product, steer clear of Vista 64 bit. WAIT until there are WHQL drivers for the silicon image controllers. If you're going to upgrade to Vista, get the 32 bit version and send the $10 in for the 64bit DVD. That way when 64 bit drivers are more plentiful you can easily upgrade.
Just wanted to share this with anyone who's think of going 64 bit and Vista.
Note: 32 bit Vista works fabulously... i have it on my laptop.
