Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problems installing XP - NTLDR missing
Forum Windows XP : Windows XP General Discussion - Problems installing XP - NTLDR missing
I recently upgraded my motherboard and processor and subsequently did a quick format of my c: drive to do a fresh install of XP. I'm having problems installing it though. Everytime I tell the computer to boot from the CD it keeps telling me that a file called NTLDR is missing! Can anyone help me out please?
Thanks.
My rig:
Core 2 Duo E6600
ASRock 775Dual-VSTA
1x512MB DDR + 1x1GHz DDR
160GB HD
Enermax 350W
Sponsored Links
since you have updated your motherboard, it could be that your cd-rom jumpers are not set correctly. i would recommend you go to this link. it should help you out.
Computer Hope
Reply to khansm
There are 1365 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
