Archived from groups: alt.tv.tech.hdtv (More info?)
What is a good remote (Sony 3100 or Harmony 659) to replace the Sci
Atlanta 8000HD cable box PVR remote. I need to control Sony TV and
sound system. The special buttons (list, Guide, A, B and C etc) need
to be mapped to the new remote
Not exactly what you're looking for, but I've had good results using a Sony
3000 with my Motorola DCT-6200. Between the standard buttons & the custom
labels, all the features of the cable box remote can be covered.
"Al Aldrdige" <alaldridge@worldnet.att.net> wrote in message
news:kuvkq0p9grcsi7fe54trd5dvki161k830f@4ax.com...
I use this remote to control my SA8000HD, Samsung DLP, plus Toshiba DVD,
RCA VCR, Pioneer Home Theatre Receiver, and Zenith OTA HD Receiver:
I have the Harmony, and it works "well" but it's slow to program and slow to
change channels. You can tweak almost anything, and to be fair, I have not
done this to speed up channel changing. I'm not sure I like having to
connect to the web to program the unit, but it's worked fine. I am
controlling the TV, Stereo receiver, Satellite receiver, DVD, VHS and
Playstation. It's not hard to program, but will take a bit of time to learn
it.
sc
I got one of those as a gift and have never set it up. I have the same Moto
box you do, but the dual tuner model.
"Jeff Henkels" <jeff@mapson.jeffhenkels.com> wrote in message
news:jPCdnXH-8cneGTfcRVn-hA@speakeasy.net...
> Sony 3000 with my Motorola DCT-6200. Between the standard buttons & the
> custom labels, all the features of the cable box remote can be covered.
I have looked at all the remotes and have order the Harmony 680,
Seems like this one will be quick to setup, Lots of info on
www.remotecentral.com
Thanks for all the input.
>it.
>sc
