Memory problem, please help!
reflexus
19
I just bought P5B Premium with 4 gigs of memory Crucial Ballistix from Newegg.
I got 2 channels, when i insert memory in the first channel comp does not even boot up and dont work, when i insert in the second channel, it works fine
Basically, first channel of 2 slots dont work at all.
Is it mobo's problem? please help.
Any input is appreciated.
Thanks in advance.
reflexus
19
4 of them the same and expensive :) second channel is working fine with one or 2 memory, first channel does not work with the same memory.
Phanboy
49
Thanks in advance.
I would RMA your motherboard. Sounds like a manufacturing defect.
