Help with headphones and speaker system
My specs
Creative X-Fi XtremeMusic Soundcard
Logitech Z-5500 500 Watts 5.1 Speakers
Razer Barracuda HP-1 Gaming 5.1 Headphones
Just wanted to know if there is anything I can do to save me time and effort about having to swap my speakers to headphones without having to
remove the cords from the back each time.
Both speakers and headphones are 5.1 sound so they both have 3 connectors and realy gets annoying having to change them each time
thanks any help would be greatly apprieated
6 answers Last reply
More about help headphones speaker system
  1. ANYONE??????
  2. Perhaps a stereo mini Y splitter for each stereo mini cable, though you would still have to pull out the headphone cables if u don't want them to output.
    Otherwise, you could get a A/B zone switch but those things cost as much as your Z-5500s.
  3. You need an audio switch, as I had similar problem before. But for me I have 2.1 speaker and a Bose Triport, each have a single 3.5mm connector. The switch I have is a simple design. But right now I'm looking for a 3 3.5mm connector for speaker and 3 3.5mm connector for your headphone. You might need a receiver is you can't find an audio switch for your system.
  4. well I was thinking I could use a home entertainment receiver would that do the trick as i have 2 lying around here, and will the sound be as good through a receiver?
  5. I have the Z5500's an I use the input on the side of the LCD console that came with the set, try that it should work for you. There are two jacks on the
    right side of your LCD receiver one is for AUX and the other for headphones.
  6. Quote:
    Yeah I've seen that on the console, but as I have 5.1 heaphones which has 3 plugs and on the side of the console is only one spot for just one plug.
Sound Cards Speakers Headphones Components
