First build and first post, Hello!
Anyways, I am building my first computer and I am asking for everyone's help so I make correct choices and not end up burned! Budget is not an issue, but I'm not looking for outrageous but rather the best bang for the buck. I have a few ideas, but I don't have the confidence nor the experience to purchase these things w/o some help.
CPU
Originally an AMD fan (currently on x2 4400+) but want to switch to C2D
Processor - Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor
Fan/Heatsink - ZALMAN 9700 LED 110mm 2 Ball CPU Cooler
MOBO
One of my bigger worries, I want to be sure I get the correct mobo with the best options
EVGA 122-CK-NF68-T1 LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard
Not sure here. A lot of good ones, but I don't know which would best suit me. Not going to use SLI, but isn't high AMPS on the 12v rail recommended? Multiple 12v rails better than single?
MEMORY
Depends on the MOBO I guess, but if I would go with DDR2-800...
CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel
HDD
Would like to go RAID 0
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive x 2
CASE
I want to make sure I have enough room for everything, so if the case is huge it doesn't matter. But I want to make sure the MOBO fits too.
Choice #1 - Thermaltake SHARK VA7000SWA Silver 1.0 mm All aluminum ATX Full Tower Computer Case
Choice #2 - NZXT Zero Black/Silver Aluminum ATX Full Tower Computer Case
MONITOR
I want to go widescreen with the best bang for the buck
SAMSUNG 226BW Black 22" 2 ms (GTG) DVI Widescreen LCD Monitor 300 cd/m2 1000:1(DC 3000:1)
That's it for the basics. I already have the keyboard (Saitek Eclipse II) / mouse (Logitech G5 Laser) / GFX card (8800GTS 640mb DDR3) so those are covered.
So, if I could have your opinions AND recommendations for the parts! All of these I have listed are just my best guesses and are by no means correct.
Thanks in advance for everyone that helps me out!
CPU
MOBO
PSUThe above mentioned MOBO supports DDR2 1066 RAM and comes combo'd with the ram, good choice or should I stick with a different MOBO and DDR2 800?
MEMORY
HDD
CASE
MONITOR
