Tom's Hardware Forums » Motherboards & Memory » General Motherboard » PC won't power on!!! Emergency Help!!!
Add a reply
 Word :   Username :
Bottom
Author
 Thread : PC won't power on!!! Emergency Help!!!
Profile: enthusiast
More Information
Hi, I just finished putting together a new build.
I used this Mobo.
http://www.newegg.com/Product/Prod [...] 6813138041
I have plugged in everthing.
But I think somehow I might have plugged in the front bottons/led wrong?
I have put everything like the manual said, but it wont turn on.
The only thing I see is that the Power LED, is always on, but the pc wont turn on itself.
Anyone know where I could have made a mistake?
Related Pr oduct
Profile: newbie
More Information
After you've troubleshooted the other normal stuff ( make sure it's grounded, the PSU workes, etc)
-Take off the "POWER SW" cables and then touch the two pins with a screwdriver or something metal, and see if it powers on then.
Or if that doesn't work...
- take out the ram, try to turn on using same method above
take MB out of case and try it again (grounding problem)
then come back and report. I bet once you try to turn it on with a screwdriver, it'll remember that it works and you'll be good once you put it back on.
Quote :
I used this Mobo.
Profile: old hand
More Information
When you say you've plugged in everything, you still may have missed something and you think it's all good. List what you have plugged in and make a checklist so we can help, like this:
4-pin CPU power plugged in
24-pin main power plugged in
PSU plugged into outlet
PSU back switch is on "-" (closed circuit = on)
PSU back is on "115" NOT "230"
etc. etc. etc.
That way, we know what you've tried and are certain that everything is truly good to go.
Profile: enthusiast
More Information
ok i found the problem
I had the 24 pin power from the PSU to the mobo plugged in, AND I had also plugged in the addition 4 pin power from PSU to mobo.
What I did was remove 4pin (from the 24 pin) and left it like 20pin + 4 pin.
So I guess I cant have both of the 4 pins plugged in at same time.
thanks for help anyways guys.
Profile: journeyman
More Information
umm Ladic how does that motherboard work.. i've been looking at that board and was thinking of getting it .. .. does it seem sturdy anything wrong with it?.. the LAN work ok?.. any thing else i should know.. thanks
gonna hit a Socket AM2 athlon64 3800+ on it
1gb DDR2 800
7300gt..
but yeah just wanted to get some of your feedback before i make the purchase
thaankss
Profile: enthusiast
More Information
everthing works great, just dont connect both 4 pin plugs.
connect the 20 pin power plug, and the connect and 4 pin power plug thats all the way up top of the mobo.
Profile: old hand
More Information
That's a really weird problem you have. By all accounts, you should have both 4-pin (CPU power) and the 20+4 pin (main power) connected at the same time. I think the +4 connector on the 20+4 is used to give extra power to the PCIe graphics card... but I may be wrong. I do know that if you have a 20-pin power supply that you can do without the +4 pin in most cases.
Is it possible to test your power supply on another motherboard or try a different power supply on the BIOSTAR board you already have?
Profile: enthusiast
More Information
I have used this psu on a different mobo before, but it was an old socket A 20 pin power and worked great.
Right now, it seems evertying is working fine with the 20 pin and theother 4 pin plugged in.
Very weird that it would not work with both 4 pins plugged in.
Add a reply
Google Ads
