Hi, I've already got an Antec P180 case and need to get a power supply. I'd like it to be modular and around 100$. Anyone who has a P180 let me know what PSU you are using.
thanks
Sponsored Links
I have a similar question.
I would like to know if all the market power supplies available til today are compatible with the Antec P180/182 series.
I see the Enermax Galaxy DXX 1k PSU pretty big for the P182 case...
Reply to slim142
It would be helpful to know the spec's of your PC in order to recommend a PSU within a specific wattage range.
Reply to Anryha42
I would like to know if like Ill need to take out the fan of the PSU section or something like that to make fit 1k PSUs
Reply to slim142
Quote :
When looking for PSu information you need to list your system specs. Most all PSU are compatible with the P18x line of cases. It's just that the P4 cable can be a bit of a stretch on some units. Moding the cable to add length or using an exstention is a good option. But most of all you need to list your system specs.
He's right. I have the p180 and enermax noisetaker II psu and I had to buy an extension for the P4 cable. other than that most psu's will work fine.
Reply to smartel7070
Ill answer the original Question i have a p180 and used to use an ANTEC NEO480 now im using the NEOHE550 from antec. had little problems with either. I would also suspect that if you did have problems fitting a long PSU in the P180 you could always remove the 120mm fan from there it should give you more room (just a thought)
Reply to chookman
I have a PCP&C Silencer 750 Quad in mine and I didn't need extention cables and I left the lower fan in place. Just have to take your time and plan out your cabling. Did have to zip tie some cables to keep them from hitting the lower fan.
Reply to occdavid
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > ANTEC P180 and power supplies
There are 1162 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
