Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Need new "silent" case
Forum Homebuilt Systems : General Homebuilt - Need new "silent" case
I am trying to find some parts for my brother and he wants a case that is as "silent" as possible, without going through the roof price wise, without PSU.
I know, a case is in it self silent except for any fans it might come with, but what is meant is that it cannot be some cheap assembly that will start vibrating and what not...
Can anyone recommend a make and/or model please?
Sponsored Links
Quote :
Antec P180. End of.
I would half disagree, p182 instead :p Better cable management
that, or the thermaltake armor full tower
Reply to I_Love_Tacos
I got an Antec P150 for my parents' PC and was amazed at how quiet it was. And should you not like the P150's snow-white color, the Antec Solo is the same case in black and silver and without a NeoHE 430 PSU (also surprisingly quiet).
Reply to rsquared
Curious...What is the best quiet case out there with a window ...Cost no object deal?
Anyone?
Reply to xsamitt
Probably the watercooled kandalf by thermaltake, slap on their special side panel with a 25cm fan, and you're onto great cooling and pretty quietness, though a watercooled p182 would be better, it won't have a window
But that's only because the fans are designed to be quiet in the sonata, it's very cramped up in that case so I wouldn't go with it, the p182 would be a smarter choice for a no cost issue person
Gigabyte Poseidon. If you don't want the blue LED exhaust fan, replace it with a Scythe S-FLEX or some other silent fan. Plus, you have the option of wire mesh or a window on the side.
Reply to chedrz
Alright thanks a lot fellows. It seems like there's a general consensus the Antec P series are great, so I will definately look into them!
Thanks again, really appreciate all the feedback!
Reply to samsayit
cool, pm me or msn me for more info if you'd like
The NZXT Lexa is pretty quiet for a window case too. I think all their fans run at 1100rpm. But I still suggest the Antec P series. My friend has an Antec P180B with a Zalman CPU cooler and VGA cooler. Whole thing runs at 20db (not quite silent, but near enough).
Reply to DarksideDragon
But it's not just about fan speed, the p180b's sound dampening helps too, though it adds tons of weight
antec solo/p150 for sure.
hard drive suspension pretty much halves seek noise, lovely finish and supurb build quality, and it's not a ridiculous size like the p180.
PS windowed cases can rarely be quiet, not to mention rubbish at shielding RF frequencies.
Reply to chrisbrown
The p180's size isn't ridiculous you just need to get used to it. It's great you once thinking about watercooling and what not
i dunno, i find all pc cases too big really...
if you're particulary anal about pc noise, air cooling is quieter than watercooling. however most people on tom's don't seem to be into super-silencing, haven't read many threads on PSU fan swaps, or undervolting :?
Reply to chrisbrown
no, that's not true, that all depends on what pump you have, and what fans you have on your radiator. Don't put down something unless you are willing to compare high end to high end. If you compare the high end silent hsf, then you need to compare them to high end watercooling parts, and almost all of swiftech's parts are silent
nonono, im not putting anything down!
a fully passive system - cpu, gpu and northbridge - with a 120mm nexus fan in the PSU and exhaust, both at 5v can barely be heard above ambient room noise, with the main source of pc noise being the hard drive seeking.
of course you can't do super overclocking, but it all depends on noise sensitivity and definition of silent i suppose :)
have a gander at http://www.silentpcreview.com/
Reply to chrisbrown
But I already have a dead silent system with the exception of my zalman hsf, so that just shows even with 5 case fans, it's all about what fans they are, not how many, because my single zalman hsf is far louder
yee man i know, that's why i specified the nexus (nexi?) at 5v :)
anyway, the OP asked about a silent case so i just thought i'd share my personal experiences. i dont really post on here that often unless i can properley relate to something :?
Reply to chrisbrown
Quote :
I like a tower case like this with lots of room and fan bays. Run the fans at 7-8 volts and all is quiet:
Chenming CMUI-P-601AEB-0 Blk SOHO Tower w/o PSU $60+16 3/31/07
http://www.newegg.com/Product/Prod [...] 6811125480
(2) Scythe 3110KL-04W-B19-EB1 80mm 1400rpm Fan $9+5 3/31/07
http://www.newegg.com/Product/Prod [...] 6835185034
or get Panaflow low speed fans when available.
In any event, check out http://www.silentpcreview.com for more info.
Reply to Newf
All of the Antec's are well made and pretty quiet, I have built a few PC's using their SOLO case:
http://www.pcnation.com/web/details.asp?item=K17801
Reply to glockman
Quote :
Yeah, sorry, forgot to mention that. Well picked up on :D
Personally, I'm going to get the Lexa because it's fairly quiet, looks nice (imo) and isn't stupidly heavy (matters a little bit as I go to LANs). But, yes, window cases will never be really quiet because they lack the dampening.
If you go to lan parties, then the p182 and definitely the p190 are not for you. The p190 weighs over 50 pounds on its own, but that will at least give you a work out :tongue:
computer~smart people-not geeks~need to work out too ya know :D
- 0 +
Just built a system in an Antec Solo case. I second that recommendation. Only bad thing compared to bigger cases that I noticed is, if you ever need to change the PSU, you have to completely disassemble the system again, e.g. remove the motherboard and that big heat sink in particular. My aim was a quiet, but fast system and I researched components fairly thoroughly. Perhaps it will be of interest. There are only 3 sources of noise in my system, which are, in the order of producing most noise, the hard disk, the Antec case fan, then the PSU fan. Here's what I came up with:
Corsair HX520 PSU. Based on Seasonic, which have a reputation for quietness. One 120mm fan on bottom, which spins up gradually. In practice it always spins very slowly and quietly with 1 Core 2 Duo and 1 mid-range graphics card loading it (see below).
Thermalright HR-01 heat sink with fan duct. This is a passive CPU heat sink, but the fan duct connects it to the case fan, which therefore stands in for the CPU fan as well. With the fan duct, the heat sink remains cool to the touch, even with E6600 overclocked to 3.2GHz. The Antec fan has 3 speed settings. I leave it at the lowest, which is quite sufficient. Interestingly it is not designed to be speed regulated, aside from having the manual 3-speed switch. In practice the constant fan is nice and unobtrusive. The fan noise ties with the hard disk when it's not seeking.
Powercolor X1950 Pro SCS3 completely passively cooled graphics card. The reviews say the passive cooler actually works better than the stock one. I wouldn't argue with that and, of course it's completely silent.
Hard disks. I chose a Seagate. Samsung are possibly quieter and they have some slower, still quieter disks for consumer electronics, which might be worth investigating.
Reply to FH
Quote :
Bah! 50lbs is chump change. 8) :lol:
Reply to Arrowyx
perhaps, I curl 40s in each arm so 50 pounds isn't all that much, but I definitely wouldn't use it as a lan case
There are 812 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
