Archived from groups: alt.tv.tech.hdtv (More info?)
In spite of all the complaints about the Samsung audio sync issue, I bought
a HLP4663 at Circuit City after being assured the issue had been resolved.
It hasn't. Video and internal audio lag behind external stereo speakers on
non-HD signals. If I play internal and external speakers I get the echo
I've heard so much about.
Before taking it back I thought I would call Samsung. They told me they
have a new sound board that takes care of it and a tech would call me to
schedule a repair. This surprised me since I had heard Samsung
couldn't/wouldn't fix this problem. I will post a follow up after Samsung
calls me back (they said today).
Lew
> Lew
Turns out I talked to Samsung's authorized repair facility in my area, not
Samsung. Samsung told them: Internal audio is delayed to match video
delay but external audio feed is NOT delayed. Samsung suggests buying a
new surround sound system with audio delay built in. Translated, if your
input signal is not HD or progressive scan, (in my case, non-HD Dish
Network), you will have sync problems if you use an external audio source
such as a stereo or home theater audio system unless your system has audio
delay.
For me, this is not an option, so it's back to Circuit City for the LG
RU44SZ63D.
Lew
I've been considering the Samsung DLP's but if this audio delay problem
really exists then I'm not about to replace my Yamaha 5.1 super sound
system.
I have DirecTV and use the pcm audio connection to the Yamaha. I like to run
the TV speakers at the same time.
Is this a problem with all hdtv's? Or just the Sammy's?
Hal.
> delay.
> RU44SZ63D.
> Lew
>>Lew
> delay.
Samsung fixed my set for this problem. They replaced two boards and the
problem disappeared. However, my set was an HLN, not an HLP. This fix
is available under warranty to any owner - just call Samsung support.
Keep in mind that there are many places along the transmission path
where the audio and video can lose synchronization. It's quite possible
that you are observing a problem that is already in the signal when it
reaches you.
In any event, good luck getting it straightened out. If it is in the
original signal, a delay in your receiver is the only thing that will
fix it. Buying a different set won't help.
> system.
> Hal.
>> delay.
>> RU44SZ63D.
>> Lew
I think video lag is just a problem with DLP type HDTVs. With my system,
when I run the TV speakers and my stereo, I get an echo. If what I was
told today is correct, getting sound boards replaced won't solve the
problem.
This only happens on signals that have to be converted such as non-HD cable
or satellite channels. HDTV channels and DVDs don't have a problem. Maybe
my satellite/converter/stereo setup makes it worse. The tech who heard it
over the phone said he hadn't heard an echo that bad.
I haven't heard of any audio problems on other DLP brands. Maybe they
compensate for the lag in a different way.
Lew
>>>Lew
>> delay.
> reaches you.
I never had a sync problem with my old 26" TV and my stereo and they were
hooked up exactly the same way.
Samsung has offered to replace my sound boards even though they don't think
it will help. Maybe I'll call them tomorrow and have them do it anyway.
If it worked for you, maybe it will work for me. If it doesn't, I have 30
days to take it back. Thanks for the input.
Lew
"Lew" <notme@notmindspring.com> wrote in message
news:13dk8aa4oj58k.mjcx73vq8b4z.dlg@40tude.net...
bought
resolved.
speakers on
echo
they
to
Samsung
> >>>Lew
not
a
your
source
audio
> >> delay.
> > reaches you.
think
> Lew
Sound sync problems happen with many systems. The problem starts because of
the difference in time between uncompressing DIGITAL video and audio. Since
video takes much longer to uncompress due to it's complexity it takes longer
to display. This was recognized when the HD standard was developed and HD
transmitters delay the sound by a known number of ms and in the standard
there is a known number of ms delay for the TV to delay the sound so that
the sound and picture are in sync.
If the Manufacturer uses a faster CPU/system for their decompression or
manage to develop a faster algorithm they need to reduce the sound delay on
their end and the converse is true. This is why most sound sync problems
occur in the device that is uncompressing the HD signal i.e.: the set top
box or cable box NOT the TV. Customer hear about the sound sync issue and
assume it's the TV. So far, in my experience, most have been the cable box.
Compounding the above is the difference in work that the digital board has
to do with various inputs to buffer and process a signal. The Ant-in and
composite video inputs require more work/time to display a picture than the
component inputs do. So there is a difference in the time delay required
for each input type. Samsung had a fixed delay on their early sets (HLN and
early HLM) and had to release a new digital board that had adjustable sound
delay. Later models (HLP) have this as a service adjustment of between 1-3
ms The Set doesn't have different delay settings for each input type so
there can be a slight defense in sync. We are talking about 1ms here. Only
the most critical gamer with his face in the screen should be bothered by
this. The simple cure is to use the component inputs for everything.
On Fri, 3 Dec 2004 06:07:26 -0500, Jeff Rigby wrote:
<snip>
My problem isn't with different inputs. It's what the TV does with the
sound after all that conversion. It sends a compensated (delayed) signal
to the internal speakers but not to the external feed. When I'm watching
Fox News with my stereo on, sometimes I notice the sound slightly before
the lips move. When I have both stereo and TV speakers on, there is an
echo. When just the TV speakers are on, I don't notice the sync problem.
As for it being 1-3ms, I had the Samsung tech listening on the phone and he
said the echo was quite noticable. I'm sure a lot has to do with my setup.
My Dish receiver doesn't have component outs so I can't use component
inputs.
You're probably right about most people not being bothered. Last night my
wife and son told me they loved the TV and didn't want me to take it back.
The sync problem doesn't occur with my DVD player (DVI input) and watching
movies is mostly when we use the stereo. I guess I'll keep it.
Everything's going to be HD in a year or so anyway.
Lew
I wouldn't recommend running both sets of speakers at once. The sync
issue is only one of many reasons not to do that. The speakers in my
Samsung are never used. All sound comes through my 5.1 receiver.
"Jim Gilliland" <usemylastname@cheerful.com> wrote in message
news:S96dnX2kSpuBcC3cRVn-ug@adelphia.com...
I would like to see manufacturers offer HD monitors with no speakers. I
think they would look better and would fit in smaller enclosures. One thing
I like about the Sharp Aquos HD monitors is that the speakers can be
removed.
Ed
In article <BdadnRacv7Hb1C3cRVn-ig@comcast.com> "Jeff Rigby" <jffg2@comcast.net> writes:
>ms
1 - 3 msec? That is equivalent to sitting 1.1 to 3.3 feet farther from the
set. (The speed of sound in air is about 1100 feet per second in normal indoor
conditions.)
Such a short delay would seem pretty worthless.
Alan
Any ideas which systems have this audio delay feature ?
news:1szahl33yv5zu.nrhtifg993lb.dlg@40tude.net...
>> system.
>> run
>> Hal.
>>> not
>>> your
>>> source
>>> audio
>>> delay.
>>> RU44SZ63D.
>>> Lew
> problem.
> cable
> Maybe
> Lew
That's true, but I think he was running both speakers just to help
illustrate how out of sync one output was.
Also, I'd say that for such a delay to be audible as such it would have to
be a LOT more than 1-3ms. It's almost certainly at least in the tens of
milliseconds, and probably well over 100ms (though I can't really say
without hearing it myself). It's understandable that digital video
processing and decompression takes some time, but overlooking that all the
outputs should be synchronized with the video (and with each other) is the
kind of dumb engineering mistake that kind of bothers people who have spent
thousands of dollars on the product.
Exactly my point. The thing that bothered me the most was Samsung's
solution: buy a new home theater system with audio delay.
Lew
Somewhere around Fri, 10 Dec 2004 21:11:55 GMT, while reading
alt.tv.tech.hdtv, I think I thought I saw this post from Lew
<notme@notmindspring.com>:
Maybe I missed something, but I seem to recall that the problem was when you
split the audio and video before the Samsung ever gets it, so that the TV
gets the video, and the stereo gets the audio. If so, there's no way to
solve that problem without buying a system with delay.
If you are looping the audio through the TV (which doesn't have digital
audio inputs) then the TV could add a delay, although it would really need
digital inputs, wouldn't it?
With my HLP model, I only noticed a delay when the TV speakers are not
muted, even though the volume was down all the way. When I muted the sound
using the TV menu, I no longer noticed the delay, either from the TV output
nor from the DVD.
Marty - mjf at leftcoast-usa.com
"Those are my principles, and if you don't like them...
well, I have others." - Groucho Marx
On Sat, 11 Dec 2004 00:59:48 GMT, Marty wrote:
<snip>
> nor from the DVD.
I never split the audio before the Samsung gets it. I have, however,
sometimes turned it down instead of muting it using the TV menu (my
universal remote can't access the menu). After reading your response, I
tried internal muting/turning down the TV speakers.
You appear to be right. There is a slight sync problem with it turned down
and none with it muted. The times I noticed were probably when the
internal speakers were just turned down. I don't know what's happening
technically, but it's as if the audio delay switches to the audio out when
you mute the speakers this way.
If you read my previous posts, you'll see that Samsung Tech Support told me
something different. I knew not to listen to both internal and external
speakers but didn't think about the difference between turning down and
internally muting the internal speakers until your post. Thanks. It was
the only problem I had with an otherwise excellent TV.
Lew
In article <1bih7f796l4x9$.ih6i74tttylg.dlg@40tude.net>,
notme@notmindspring.com says...
What else can they suggest? If you are going to split the audio from the
video *before* it goes into the TV how the hell are they supposed to
solve the problem that your audio processor is faster than the video
processor? They -can't- make the TV faster, and they can't touch the
audio channel at all to slow it down, because you split it off.
The only solution is to delay the audio, and that can only be done by
the audio hardware.
Somewhere around Sat, 11 Dec 2004 05:37:03 GMT, while reading
>> nor from the DVD.
Sorry for the delay (rimshot) in responding, I've been sick.
Glad I was able to help you solve the problem; I'm not sure how I came upon
the solution, but I probably read it somewhere, possibly in the manual.
There are 1288 identified and unidentified users. To see the list of identified users, Click here.
