Yes No
Ads
Tom's Hardware > Forum > Home Theatre > HDTV > CBS Hi Def football problems
Forum Home Theatre : HDTV CBS Hi Def football problems
Archived from groups: alt.tv.tech.hdtv (More info?)
On CBS Hi def football games there is usally pixelation when the camera
moves rapidly and often with rapid subject movement. This does not occur
with other CBS hi def broadcasts and is not seen on any other broadcaster's
hi def football transmission, for example ESPN. Is this something peculiar
to CBS or the local affiliate that rebroadcasts the signal? Changing
resolution in the receiver, 720 or 1080, makes no difference. Unfortunatley
the local dork broadcasters for ABC and FOX do not rebroadcast the hi-def
signal or allow satellite reception.
Reply to Anonymous
"bmoag" <apquilts@pacbell.net> wrote in message
news:kA2sd.53637$QJ3.30100@newssvr21.news.prodigy.com...
: On CBS Hi def football games there is usally pixelation when the
camera
: moves rapidly and often with rapid subject movement. This does not
occur
: with other CBS hi def broadcasts and is not seen on any other
broadcaster's
: hi def football transmission, for example ESPN. Is this something
peculiar
: to CBS or the local affiliate that rebroadcasts the signal? Changing
: resolution in the receiver, 720 or 1080, makes no difference.
Unfortunatley
: the local dork broadcasters for ABC and FOX do not rebroadcast the
hi-def
: signal or allow satellite reception.
I know that Fox, ABC and ESPN all use 720p while CBS and NBC use
1080i. That might be the difference, although here in DFW ( I don't
know where you are) I can't tell any difference, using my OTA STB,
between the two. Any artifiacts that I see, I assume are "comming
down the pike" because it's live, not recorded.
Reply to Anonymous
More than likely your TV...especially if lcd/plasma. They do not handle
rapid motion well.
And your tv will only display one hd format...regardless of what you select
at the receiver.
> broadcaster's hi def football transmission, for example ESPN. Is this
> something peculiar to CBS or the local affiliate that rebroadcasts the
> signal? Changing resolution in the receiver, 720 or 1080, makes no
> difference. Unfortunatley the local dork broadcasters for ABC and FOX do
> not rebroadcast the hi-def signal or allow satellite reception.
Reply to curmudgeon
"bmoag" <apquilts@pacbell.net> wrote in message news:<kA2sd.53637$QJ3.30100@newssvr21.news.prodigy.com>...
As I understand it, there are two possible sources for pixelization.
One is when the broadcaster does a poor job of MPEG2 compression.
What I've noticed is that the problem is very common in live
broadcasts such as sports, and much rarer when showing film-like
sources such as prime time dramas. When they rely on automatic
conversion in real time, you don't get the quality that is possible if
something is prepared in advance.
The other possible source is when the network sends a good feed but
the local station is enamored of multicasting, and has to convert the
image to a slower bit rate.
Reply to Anonymous
In article <e5747637.0412031454.126e6a68@posting.google.com>,
paul-NOZPAM@paulkienitz.net (Paul Kienitz) writes:
MPEG2 encoding for film does so with a 24fps source, and there is ALOT
of redundancy when converting to 60i. This allows for significantly
more apparent compression than with a real live scene, which would have
effectively full 60i temporal detail. Of course, true 24fps MPEG
encoding instead of 60i encoding of 24fps would be better, but full
60i encoding (e.g. for live sports) is significantly more challenging.
There is actually MORE TEMPORAL detail in a live 60i broadcast than
for 24fps film material (many fields are low overhead repeats.)
So, live encoding is closer to the 'edge' for pixelization or other
gross scale MPEG compression artifacts than 24fps.
There is also the opportunity for non-realtime compression for film
material, but I suspect that the innate redundancy of film material
is the biggest difference. I doubt that offline compression is done
very often for movies anyway. (AFAIK, CBS doesn't really do a full
ATSC encode for its stations, and that is done at the TV station
itself. SO, there isn't really an opportunity for non-realtime
ATSC encoding.)
John
Reply to Anonymous
It's either your set or your local station or cable provider. CBS
football games in LA are amazingly clear.
Bill
broadcaster's
peculiar
Unfortunatley
hi-def
Reply to Anonymous
- 0 +
>at the receiver.
Not true. Many TVs display 480p/720p/1089i without conversion.
Reply to abe
toor@iquest.net (John S. Dyson) wrote in message news:<coquq2$1nob$1@news.iquest.net>...
You're probably right.
Reply to Anonymous
>>at the receiver.
Care to cite some examples?
Matthew
Thermodynamics and/or Golf for dummies: There is a game
You can't win
You can't break even
You can't get out of the game
Reply to Anonymous
- 0 +
"Matthew L. Martin" <nothere@notnow.never> wrote in message news:10r3bjf698dq16@corp.supernews.com...
> >>at the receiver.
Princeton AF3.0HD.
MH.
Reply to mh
"MH" <blah@blahblah.blah> wrote in message
news:31ds0lF3ar8j8U1@individual.net...
select
> > >>at the receiver.
> Princeton AF3.0HD.
Hmmm. Good example. A product that is not even made anymore. Actually,
most CRT based sets for the consumer market operate at only one or two scan
rates (for 480p and 1080i). I would be surprised if you could find many
displays at sizes appropriate for home theater at reasonable prices that are
able to do all scan rates with no resampling or scaling. Just about the
only things out there are multiscan computer monitors and projectors.
Leonard
Reply to Anonymous
- 0 +
>Matthew
OK. This is Sony and Panasonic specific, because I didn't want to
spend alot of time copying and pasting model numbers from different
manufacturers.
30" Widescreen FD Trinitron® WEGA® HDTV KD-30XS955
http://www.sonystyle.com/intershop [...] 0XS955.pdf
34" Widescreen XBR® HDTV KD-34XBR960
http://www.sonystyle.com/intershop [...] XBR960.pdf
36" FD Trinitron® WEGA® HDTV KD-36XS955
http://www.sonystyle.com/intershop [...] 6XS955.pdf
TC-32LX20 32" Diagonal Widescreen LCD HDTV
http://www2.panasonic.com/webapp/w [...] =LCD%20TVs
TC-26LX20 26" Diagonal Widescreen LCD HDTV
PT-50DL54 50" Diagonal Projection HDTV Monitor with DLPâ„¢ Technology
http://www2.panasonic.com/webapp/w [...] 20Monitors
....and many others...
Reply to abe
Abe (noone@nowhere.com) wrote in alt.tv.tech.hdtv:
Well, he's zero-for-six. All of these sets convert at least one of the
HD modes to another of the HD modes.
These are direct view CRTs that support only 480i, 960i, 480p, and 1080i.
With DRC enabled, all 480i signals are converted to 960i or 480p. With
DRC disabled, all 480i signals remain at 480i, 480p signals remain at
480p, and all other signals are converted to 1080i.
These are LCDs. They are inherently progressive scan. All signals are
converted to progressive...in this case, 1280x768/60p.
> PT-50DL54 50" Diagonal Projection HDTV Monitor with DLP? Technology
This is a DLP. It is inherently progressive scan. All signals are
converted to progressive...in this case, 1280x720/60p.
Jeff Rife | "I'm reading a great John Grisham novel...it's
SPAM bait: | about a young Southern lawyer who fights an
AskDOJ@usdoj.gov | evil corporate giant."
spam@ftc.gov | -- Dick Solomon, "3rd Rock from the Sun"
Reply to Anonymous
- 0 +
I'm confused. Educate me.
The specs for each of these sets say that they display 480i and
p/720p/and 1080i. None of the specs say anything about conversion. So
how would one know what's being converted to what? Specifically, where
can I see it in print from from an objective source?
Reply to abe
"Abe" <noone@nowhere.com> wrote in message
news:l234r0tidt7hcvoddgg88ogtbai53ol1pi@4ax.com...
> >Matthew
> manufacturers.
> PT-50DL54 50" Diagonal Projection HDTV Monitor with DLPT Technology
Actually, none of the sets that you list will display all scan rates without
conversion. You might want to do some homework. You may be able to watch
all of the formats, but at least one, and in the case of the non-crt sets
all but one format will have to be converted.
"Many others" is simply not true.
Leonard
Reply to Anonymous
news:7284r0582f97io79euumgett4ok6i661a9@4ax.com...
http://www2.panasonic.com/webapp/w [...] Model=PT-5
0DL54&surfCategory=DLP?%20HDTV%20Monitors
It is easy to get confused and hard to find clear explanations. You would
need to get the service training literature to get a description of the scan
rates for most displays. Fixed pixel displays have a native resolution
determined by the display design. All other formats have to be resampled,
converted, or scaled to fit. CRT based sets can be made to operate at many
frequencies but each additional format that is displayed without conversion
increases the complexity of the set and its alignment. Jeff's explanation
was quite good and very correct.
The bottom line is that being compatible with a display or transmission
format is different than displaying it in its native form. It would be
desirable to do so because nearly any conversion is going to involve
approximations and visible effects.
Leonard
Reply to Anonymous
<snip>
I have the same issue here. Football on ABC and ESPN Hi-Def is beautiful.
But the CBS games are pixelized during rapid movement. It's irritating.
I think it might be the local affiliate, because it's the same way OTA and
through HD cable. But the ABC looks great, both OTA and through cable.
Zenith C34W37 here.
Reply to Anonymous
"Jeff S" <jeffs210@NOSPAMsio.midco.net> wrote in message
news:j007r0h7c4r0ihvcl3r537rdvgole0pc2p@4ax.com...
broadcaster's
> <snip>
> Zenith C34W37 here
In Austin, via Time-Warner Cable, seems to me that ESPN football has the
best HD, with CBS next -- no pixelation problems of consequence that I have
seen. FOX is next, with their HD quality varying from game to game. Some
games beautiful, some good but not quite CBS, ESPN quality. The local ABC
affiliate is having some problems recently, I think, with their HD going out
completely for some games. The Big 12 Championship Game (if you can call
that a "game" ), for example, was broadcast nationally in HD but here in SD.
mack
austin
Reply to Anonymous
my original reply:
>"I know that Fox, ABC and ESPN all use 720p while CBS and NBC use
>1080i. ...
The 720p will allow for a smoother picture without pixelation. 1080i
will, by default, have a bit more problem with a live telecast just
because of the interlacing.
<snip> > Any artifiacts that I see, I assume are "comming
I'll finsh that by saying live is more challenging than "recorded".
Russ
: "bmoag" <apquilts@pacbell.net> wrote:
: >On CBS Hi def football games there is usally pixelation when the
camera
: >moves rapidly and often with rapid subject movement. This does not
occur
: >with other CBS hi def broadcasts and is not seen on any other
broadcaster's
: >hi def football transmission, for example ESPN.
: <snip>
: I have the same issue here. Football on ABC and ESPN Hi-Def is
beautiful.
: But the CBS games are pixelized during rapid movement. It's
irritating.
: I think it might be the local affiliate, because it's the same way
OTA and
: through HD cable. But the ABC looks great, both OTA and through
cable.
: Zenith C34W37 here.
Reply to Anonymous
There are 2006 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Sound Bars
By americanaudiophile, 23 days ago:
If you want to connect the receiver zone 2 to the soundbar then you need a speakers to...
Best offers
