Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Which water cooling system?
Forum Overclocking : Cooler and Heatsinks - Which water cooling system?
First of all, here are my specs:
-AMD FX-60 Dual Core processor
-Maxtor 500GB HD (7,200 rpm)
-2GB of RAM (Corsair)
-2 7800GTXs running in SLI
-ASUS A8N32 mobo
Now, my question is, which water cooling system would you guys recommend for me? Because when I play games, my system is running hot...
I have a Quantum case, with the stock 7 fans, and I guess they are just not enough...
Please help.
Sponsored Links
Check Petra's......the master:
http://www.petrastechshop.com/pecosliba.html
Excellent kit, not overly expensive, very good quality, has everything you'll need.
Just make SURE those GPU blocks fit your graphics card model. I'm too lazy to find out, so let your fingers do the walking.
Reply to skyguy
Just curious... How cool will it keep my hardware? Thank you for the reply btw.
Reply to makinasvp
It depends.......what your case airflow is like, your ambient temps, if your CPU is overclocked, etc.
As a good example, I've just finished upgrading to a watercooling setup....smaller pump, but no GPU blocks......and my temps have dropped 11C idle / 21C load. And that's from a good aftermarket air heatsink on the CPU.
I'd say that's pretty darn good ;)
Reply to skyguy
There are 678 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
