Archived from groups: alt.tv.tech.hdtv (More info?)
I have a Dish Network HDTV configured satellite dish and a Dish 301
receiver. Can these two be hooked together? I'm not after the HD
service. I have the receiver from my orignal install and picked up the
dish with the HDTV LNBs for free as an extra.
Does anyone know where I can find some sort of install instructions
for hooking this up?
no such thing as a HDTV dish for dishnetwork.
"Damian Colden" <dacassoc@diws.com> wrote in message
news:19b7fd05.0412050845.1f3c57ea@posting.google.com...
the
The dish I have has the "Super Dish Network" logo on it. It has two
LNBs mounted on the arm. The larger one, mounted in the center
position, says "HDTV" on the housing. The smaller one, mounted to the
left of center, says "Dish Plus" on it.
Any ideas about what I've got?
you have a super dish, it picks up 110,119 and 121 or 105, run a switch ck
and it will say 105 or 121. Your locals are on 105 or 121
news:1102341256.380884.126090@c13g2000cwb.googlegroups.com...
> the
switch ck
Thanks for the response. I'm assuming that I can hook a Dish DP301
receiver to this dish and get the basic range of satellite channels
available to the DP301 receiver.
yes
news:1102559189.261416.17520@c13g2000cwb.googlegroups.com...
> switch ck
> Would this be a correct assumption?
