On the board where it worked, I set the system up with one adapter in the primary PCI-E slot- configured it with one monitor. updated drivers, shut down. Installed second adapter, set it active in display properties/controll pannel, and both adapters worked one monitor each. shut down, installed two additional monitors, and on boot up set all the monitors active, all work. (interleaved- adapter1con1=mon1, adapter2con1=mon2, andapter1con2=mon3, adapter2con2=mon4)
no problems. running at 1680x1050 on all four and its works great. (deployed this to a ship as a nav controll pannel system and they report no errors in 5 months hard at work) unfortunately they are out fishing or something right now and I cant just look what board I used, and I cannot remember. on the boards now (newer versions) I am trying, it wont even give me the ability to select/activate the second card- doesnt even detect it on all but one, and flags it disabled on the one. (and I have three sets of two cards , two diff mfr, two diff chipset)
