Bit of a problem on my hands here.
I have a USB Netgear Wireless Adapter for my PC (WG111T) and works fine. But, if i insert my 2GB USB stick into the spare Slot, the internet connection will drop. There is no notification saying that a USB device has been disconnected or anything. When going to wireless configuration service, it still displays as connected, even though i have no network functions available anymore.
If i disconnect, it won't reconnect. The only way to reconnect is by physically unplugging the adapater and reinserting it.
Any ideas?
Sponsored Links
Have you the most recent drivers for the Wireless card?
Reply to g-paw
Yup the driver i have is the most recent one on the website. I'm actually going to return it tomorrow. Any recommendations for a replacement? I guess i'd best be going for a PCI card instead. Any good recommendations for a wireless router also? I have the netgear DG834G.
Reply to 5aq1b
I'd go with an internal. I have a couple of Netgear 311 cards, work well and no problems. have 2 and used them in 4 machines at different times
Reply to g-paw
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Wireless USB Issue...
There are 566 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
